No "EXIT" button?
No "EXIT" button?
Postby cabbie » Wed Jul 07, 2010 10:46 pm
Searched through all the menus and settings and can't find a way to close the app. I tried just backing out of it and it stayed running. I had to use ATK to kill it. When I tried to re-open it after that, it FCed. It works again after a reboot, but this should be addressed.
Thanks for the great app!
cabbie
Postby cabbie » Wed Jul 07, 2010 10:49 pm
figured it out. On the main screen, click the drop arrow on 'server' and select 'offline'. That will break the connection and let you exit.
cabbie
Postby j3tblk » Tue Jul 13, 2010 7:57 pm
This program is amazing but there really needs to be an 'Exit' option for closing the app.
j3tblk
