Windows 7 & Airport Extreme
Postby tenkely » Thu Jul 08, 2010 5:34 am
Has anyone had any luck getting Subsonic to work remotely using Windows 7 and an Airport Extreme?
I set up W7 to use a static ip then I think I enabled the port forwarding to 80 correctly but it still says can't connect.
Any help is truly appreciated.
Update:
Went to http://www.yougetsignal.com/tools/open-ports/ and am told that port 80 is closed. Anyone know how to open port 80 on an Airport extreme?
tenkely
Postby tenkely » Fri Jul 09, 2010 5:46 am
Figured it out for anyone having a similar problem. My ISP was blocking port 80. I switched to 8080 and all is good to go. :D
tenkely
