iSub - Internet connection error mesage
Postby L4ngley » Thu Jul 08, 2010 7:54 am
Hello
I often get this error message when starting iSub:
"Error you have to be connected to the internet to use"
The wiered part is that it only happens sometimes.
I see my provider name beside the signal bars (NetCom) and 3G.
Wepages opens fine in Safari.
Dont know if it is related but i often get this Error too when getting albus lists for artists:
"There was an error parsing the XML response. Maybe you forgot to set the right port for your server?"
This happes more often on large data (artists with many albums)
If i try again, it might work. No changes in any settings.
This also happens when I am on WLAN... but not so often it seems.
Since it is working like 50% of the time i cant understnad it has anyting to do with prot forwarding. Port used is 8085. No problems with streaming from a PC.
Latest iSub and iOS v 4.0 (8A293)
Any idea on what cases this would be aprpreciated.
L4ngley
Postby opafett » Mon Jul 12, 2010 4:38 pm
I am having the same error regarding parsing the XML, with the same symptoms.
Works fine with my folders that have only a few music files, but when accessing my larger folder I get that error every time. On one of my mid-sized folders it is hit or miss, sometimes getting the error, other times loading fine.
opafett
Postby L4ngley » Tue Jul 13, 2010 6:30 am
But you don't get error "Error connecting..."?
Those two problems might not be connected then...
Hope the author of iSub looks to these forums once a while.
L4ngley
