Getting Subsonic to just work.
Postby YaKillaCJ » Fri Jul 09, 2010 3:31 pm
I have tried for the past 30mins to get it to work.
Using latest Subsonic 4.0.1 (build 1529) – May 13, 2010
Motorola Cliq Titanium - Subsonic Music Screamer 1.4 (Android Market)
Port Forwarding running and Confirmed.
Windows firewall Disabled for now (but exception added).
I seem to be getting an error on any Server address I use except the demo or my ip (*8.*42.*28.1*7:34567). I blanked out my IP of course. It says connected but but unauthorized server.
I have tried:
http://localhost
http://localhost:80
http://localhost:34567
http://192.168.2.2
http://192.168.2.2:80
http://192.168.2.2:34567
http://yakillacj.subsonic.org
YaKillaCJ
Postby WIL » Fri Jul 09, 2010 3:39 pm
I can see http://yakillacj.subsonic.org, so your port forwarding is working ok.
WIL
Postby YaKillaCJ » Fri Jul 09, 2010 3:54 pm
Exactly, lol. Yet I cant get a thing working. Idk if its the client or what. My point is I cant get it via local (Wifi) or web (subsonic.org).
YaKillaCJ
Postby YaKillaCJ » Fri Jul 09, 2010 5:01 pm
Ok I have it up and running.
The only way I can use it is via my Ext IP. Which I have no issues with. Thing is this can be more bandwidth intensive.
Basicly im saying the Local use doesnt work at all.
May become an issue if my net ever went down.
YaKillaCJ
Postby WIL » Sun Jul 11, 2010 4:31 pm
So on your local network, you should be able to just bang into the the box that you have Subsonic installed on. In my case, I have it installed on a different computer and I point to http://192.168.x.x:port and it comes right up. How are you configured? If you can see it through the external, you should be able to see it internally.
WIL
