"WARN RESTController - Invalid year: 1992-01-01"
Postby Sporkman » Tue Jul 13, 2010 1:57 am
I'm seeing a bunch of these in subsonic.log:
[2010-07-09 17:26:18,834] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-07-09 17:26:18,835] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-07-09 18:30:44,855] INFO PlayerDao - Created player 5.
[2010-07-09 18:31:25,831] WARN RESTController - Invalid year: 1992-01-01
java.lang.NumberFormatException: For input string: "1992-01-01"
   at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
   at java.lang.Integer.parseInt(Integer.java:458)
   at java.lang.Integer.valueOf(Integer.java:554)
   at net.sourceforge.subsonic.controller.RESTController.createAttributesForMusicFile(RESTController.java:582)
   at net.sourceforge.subsonic.controller.RESTController.getMusicDirectory(RESTController.java:222)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
   at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:148)
...anything I should change?
-Thanks
Sporkman
Postby Poffa » Tue Jul 13, 2010 8:51 am
I wouldn't worry.
Subsonic needs to take care of more date formats while parsing tag info. Probably Subsonic expects "1992.01.01", "19920101" or "01-01-1992" and so on. It's a bug, but not a crucial one.
Poffa
Postby Gonzo » Wed Jul 14, 2010 12:34 am
Your soundfiles contain wrong tags. In your case it seems like some smart program put "1992-01-01" instead of a 4-digit year (1992) into the mp3 tag and thereby breaks the expected format. Try to re-tag theese files (1992-01-01 sounds like some bootleg?)
Gonzo
Postby dan1son » Wed Jul 14, 2010 7:38 pm
I get this in my logs now too. I don't recall getting it before. I use musicbrainz picard to tag my files, which throws the entire release date into the id3 tag if possible. I believe the tag is "Date" and not "Year" which should be fine. Unfortunately the logs don't tell you the file, so it's hard to look.
YYYY-MM-DD is the ISO 8601 standard for date and should be acceptable for the parser.
Currently this is taking over my logfile. It'd be great to get a fix on this :)
EDIT: I also get some with YYYY-MM which I would also assume should be acceptable if only the month is known.
dan1son
Postby Sporkman » Wed Jul 14, 2010 9:23 pm
Gonzo wrote:Your soundfiles contain wrong tags. In your case it seems like some smart program put "1992-01-01" instead of a 4-digit year (1992) into the mp3 tag and thereby breaks the expected format. Try to re-tag theese files (1992-01-01 sounds like some bootleg?)
They were scanned from CDs to FLAC via Rythmbox on Ubuntu...
Sporkman
Postby Poffa » Wed Jul 14, 2010 9:58 pm
Excatly how I do it :D
I also have this "problem". Subsonic should be able to parse this format also, but it doesn't bother me that much.
Poffa
Postby baaldemon » Mon Jul 19, 2010 4:22 pm
I too was getting annoyed by these stack traces in my log file so I ended up just modifying the code myself. As I do not see any case where I would actually need the stack trace for an error of this type I pass null as the exception to the logger. I also modified it to be able to parse several types of full dates.
Code in net.sourceforge.subsonic.controller.RESTController.java
if (year != null) {
    if (year.length() >4) {
        if (year.matches("^(19|20)\\d{2}.*")){
            year = year.substring(0,4);
        else if (year.matches(".*(19|20)\\d{2}$")){
            year = year.substring(year.length()-4);
    try {
        attributes.add(new Attribute("year", Integer.valueOf(year)));
    } catch (NumberFormatException x) {
        //LOG.warn("Invalid year: " + year, x);
        LOG.warn("Invalid year: "+year, null);
baaldemon
