Setup appears to have worked. All I get is static.
Postby m3g1g1 » Sat Jul 17, 2010 2:42 pm
Greetings - I'm able to access my music from my Droid Incredible. However, when I play a track all I hear is static. Your assistance is appreciated.
m3g1g1
Re: Setup appears to have worked. All I get is static.
Postby m3g1g1 » Mon Jul 19, 2010 9:48 pm
m3g1g1 wrote:Greetings - I'm able to access my music from my Droid Incredible. However, when I play a track all I hear is static. Your assistance is appreciated.
Perhaps I didn't provide enough information. I can see my music library (most of it anyway). I can select an artist and a track. The track starts to load and play but then all I get is static.
I've found one live show (which was downloaded from archive.org) that will actually play. All other songs, whether imported from a CD or purchased from iTunes will not play. Any feedback at all out there?
m3g1g1
Postby baaldemon » Tue Jul 20, 2010 12:32 am
What type of machine is running your subsonic server? Do you have specific transcoding rules setup? What type of files are you trying to play and what are the bitrates for them? What server version are you running and what version of the android app are you running?
baaldemon
Postby bmarinari » Wed Jul 21, 2010 3:39 pm
I had this problem at first, in my case it was because transcoding for m4a files was not enabled. I'd suggest checking your transcoding page and making sure they are all checked as enabled.
bmarinari
