Why does the search not work at all???
Postby omegamuff1n » Mon Jul 19, 2010 1:01 am
I mean come on now.
omegamuff1n
Postby mgrant » Mon Jul 19, 2010 9:38 pm
I believe that the search feature searches through the index. The index is generated by scanning the tags of the files in the collection.
The list in the left pane of subsonic, however, is simply a list of sub-folders of the music folders.
Unfortunately the tags don't alway match the folder names thus the search may not return results when searching for a folder name.
To check my logic you can click the plus sign [+] by "Oh, The Humanity" on the left. Then, notice what gets added to the play list. If you search for THOSE keywords you should get results.
-mg
mgrant
Postby windstarpro » Sun Feb 20, 2011 11:28 pm
If you already figured it out, disregard. This may help others searching the forums.
I had the same problem, could see the artists, but wouldn't return any search results.
Try, >Search>Update Search Index Now
Youre index may not be populated =>No Matches Found
windstarpro
Postby donpearson » Mon Feb 21, 2011 9:49 pm
Must of been the problem then as there is no reply lol
Facebook Group:
donpearson
