Updated and now can't connect
Postby GregF » Thu Jul 22, 2010 2:37 am
I've been using Subsonic for awhile and donated awhile back...I recently updated to the new version and now cannot connect outside of my WiFi network. I've changed no settings on my computer - I'd manually set up port forwarding and haven't changed it. Is this something that's happened to anyone? When I test my subdomain inside Subsonic, I get this:
(username).subsonic.org is registered, but could not connect to it. (NoRouteToHostException)
Any ideas?
GregF
Re: Updated and now can't connect
Postby precipitous » Thu Jul 22, 2010 2:10 pm
GregF wrote:I've been using Subsonic for awhile and donated awhile back...I recently updated to the new version and now cannot connect outside of my WiFi network. I've changed no settings on my computer - I'd manually set up port forwarding and haven't changed it. Is this something that's happened to anyone? When I test my subdomain inside Subsonic, I get this:
Any ideas?
Did you check to verify what port Subsonic is using? I know that starting with the latest release (or maybe one before), the default port was changed to 4040.
Go to Settings, then Network, or to About, then look at the log to check. If the port has changed, be sure to update the port forwarding for your router.
precipitous
Postby GregF » Thu Jul 22, 2010 7:35 pm
No, it's still port 80. And like I said, I haven't changed my forwarding at all. I double-checked to make sure it was still set up.
GregF
Postby nasko » Sat Nov 17, 2018 4:41 pm
same issue here, just upgraded to v6.1.4
Did you resolve it ? How ?
thanks
nasko
Postby shanec80 » Sat Nov 24, 2018 2:15 am
Did anyone find a fix for this? Mine isn't working either with 6.1.4 using port 4040. Worked fine on 6.1.3
shanec80
Postby shanec80 » Sun Nov 25, 2018 10:17 am
Rolled back to 6.1.3, still can't connect.
Could not connect to http://youname.subsonic.org (ConnectTimeOutException)
Also note that ping yourname.subsonic.org times out, as does ping subsonic.org
Port forwarding creation also fails, but that may be because the ports are already mapped?
[2018-11-25 03:21:23,790] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: 500 Internal Server Error: Error: ConflictInMappingEntry (HTTP response was: 500 Internal Server Error)
        at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:98)
        at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:71)
        at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:130)
        at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:291)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
shanec80
