where do i set up the max bit rate to 192kbs for streaming?
Postby boxtata » Fri Jul 23, 2010 7:15 am
I am streaming to android... and some of my songs are on 320k, which makes it skip pretty badly
where do i set it to stream at 192kbs max??
I look through advance setting, and I can only find "download limit".. i am assuming that's download speed.. and obviously i don't want to limit it... right??
someone please tell me where to find that setting pls..
thanks
boxtata
Postby Poffa » Fri Jul 23, 2010 7:38 am
You need version 1.5 of Subsonic for Android to do it on your phone.
On your phone: Subsonic-->Settings-->Network (Max bitrate Wi-Fi/Mobile).
or
Web: Settings-->Users-->Max bitrate
Poffa
Postby p4madeus » Wed Jul 28, 2010 1:32 pm
It's a little disappointing that it jumps down from 320 to 160...could we get an in-between like 240? :wink:
My Droid generally can keep up with 320 if I have good 3G service and let it sit and stream a little ahead of where I'm listening before I hit play, 160 is no problem, but seems like 240 would be ideal for best sound quality paired with consistent streaming over 3G. :wink:
p4madeus
Postby courtarro » Tue Aug 31, 2010 4:57 pm
p4madeus wrote:It's a little disappointing that it jumps down from 320 to 160...could we get an in-between like 240? :wink:
I second this. For me, 160 is too low, but 320 is too high. Most of my stuff is around 200kbps average bitrate, so ideally I'd like to set Subsonic to 224kbps so that only the occasional high bitrate track (i.e. 320) gets transcoded.
courtarro
Postby delcypher » Tue Aug 31, 2010 6:57 pm
You can set a limit on the server side too.
In settings > Players. Find your android player and then set the maximum bit-rate (you need to have connected at least once before your player will appear). It be named "android [username]"
delcypher
Users browsing this forum: No registered users and 59 guests
