Streaming to Ipod Touch over Wi-fi
Postby MarkT40 » Sun Jul 25, 2010 7:28 pm
Sorry if this is a stupid question. I'm using Subsonic to stream to my Ipod Touch over Wifi (via I-sub) - replacing Simplifymedia 2. Does this send my tunes over the internet? In other words will I use use up my ISP's download limit to stream to my Ipod over Wi-fi? As I have a small download / upload limit, I'll soon run into problems if so.
MarkT40
Postby donpearson » Sun Jul 25, 2010 9:31 pm
As long as you are streaming direct from your server ie: using your servers ip address or domain (depending how your have it setup), but if your using like your subsonic domain name you will be using your internet.
Facebook Group:
donpearson
Postby MarkT40 » Sun Jul 25, 2010 10:09 pm
Thanks Don
I'm not sure what I'm doing! Can you tell me how to set it up so I am not using the internet, ie how to stream direct from your server ie: using my servers ip address or domain?
Atpresent, I have it set up, under Network, as access your server over the interent with the check box ticked and a subsonic.org web address set. Is that wrong?
Thanks for your help.
MarkT40
Postby ~heels » Mon Jul 26, 2010 11:01 am
I think Don meant in your iSub client on your iPod. Make sure that the address is your local IP (ie 192.168.1.x) and not the web address. Hope that helps.
~heels
