Adnroid APP problems
Postby rox4 » Tue Jul 27, 2010 8:19 am
I'm new here so I would like to congratulate Sindre for the great Job done.
I've been using Subsonic for 2 weeks and I don't have any complains.
Also, I've been using the android app. (I known, in a week I'll have to do a donation to continue using it... well, I'll do it if the problem I have has a solution).
Well, the think is that when I'm online, I download the music to my phone via subsonic and I can listen it without any problem. The problem comes when I'm outline...
I've a database of music which has more then 3 levels of directories. So I apparently download a song on the 4th directory. It seems to be there (it is there because I can see it on the sdcard) but when I say to subsonic to play it, it says incomprehensibly downloading... why? if it where downloaded before?
For example, I have 3 cd's.
/type/name1/CD1
/type/name1/CD2
/type/name2
so, I can download and listen outline the name2 but I can't listen the name1/CD1 and name1/CD2.
I wish the problem is well explained.
Thank you very much!
rox4
Re: Adnroid APP problems
Postby rox4 » Sun Aug 01, 2010 9:17 am
rox4 wrote:Hi,
/type/name1/CD1
/type/name1/CD2
/type/name2
I really though it was an issue... thank you for answering... (sarcasm)
rox4
Postby delcypher » Sun Aug 01, 2010 1:59 pm
Acting like a child will not get your question answered any quicker.
What is
outline
, do you mean offline?
If you want the bug fixed then speak to Sindre (the android app developer) directly giving him an adb logcat output after the problem has happened (you can use the "log collector" app from the android market if you don't have adb from the android SDK).
I don't have subsonic running right this second so I can't try reproduce your issue.
delcypher
