Covert art problems
Covert art problems
Postby Gus » Fri Jul 30, 2010 2:00 pm
Dear all,
I am experiencing various problems with cover art not downloading. Here is an excerpt from my log:
[7/30/10 3:55:51 PM CEST]   INFO   CoverArtBatchService   Looking up cover art for - The Red Hot Chili Pepper - Californication.
[7/30/10 3:55:51 PM CEST]   INFO   DiscogsSearchService   Found 0 cover image(s) at Discogs.com in 438 ms.
[7/30/10 3:55:51 PM CEST]   INFO   CoverArtBatchService   No image found.
[7/30/10 3:55:56 PM CEST]   WARN   CoverArtController   Failed to create thumbnail for /home/augustin/Music/Albums/Dark Moor - Shadowland/cover.jpg
When i look into the "Dark Moor" folder above, I notice that:
- i have a "cover.jpg" file
- its size is 0 byte
- its owner is root (unlike the rest of the folder, owned by my user account)
Any help, please?
Running Subsonic 4.0.1 on Ubuntu Lucid Lynx 64-bits.
Gus
Postby delcypher » Fri Jul 30, 2010 4:39 pm
Two points:
1. You're file is named/tagged wrong! It's "The Red hot chilli peppers" NOT "The red hot chilli pepper"
Try a search on discogs.org and you'll see that one fails and the other suceeds.
2. The fact the cover.jpg file is owned by root indicates you're running subsonic as root!
DON'T DO THAT! It's a disaster waiting to happen, subsonic does not need root privilidges. If you need to use a privilidged port (1-1024) then start subsonic on an un-prividged port as a NON-PRIVILIDGED USER and use iptables to do a redirect like so (assuming subsonic is running on port 4040 and you'd like connections to go to port 80)
iptables -t nat -A PREROUTING -p tcp --dport 80 -j REDIRECT --to-ports 4040
Note this redirect will only work when external machines try to connect to you.
delcypher
Postby Gus » Sat Jul 31, 2010 9:43 am
delcypher wrote:Two points:
Ok, I was planning to run MusicBrainz Picard on my mp3 collection once I got everything working with subsonic. I'll see if all the errors of that type can be linked to wrong names, but I doubt it.
I don't think I did anything to run subsonic as root. I just installed it as per these instructions: http://www.subsonic.org/pages/installation.jsp#debian
How do I change that behaviour?
Thank you very much for your help!
Gus
Postby Gus » Sun Aug 01, 2010 2:16 pm
Please, anyone?
Gus
Postby delcypher » Sun Aug 01, 2010 2:42 pm
I don't use Ubuntu at the moment. But the .deb installer adds subsonic as a service which may quite likely run as root.
You can find out by running
ps -o user,cmd -C java
The first column showns the username and the second column shows the command being run by that user. The -C will only display programs running called "java".
For example my ouput is:
USER     CMD
dan      /usr/lib/jvm/java-6-openjdk/bin/java -Xmx100m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -jar subsonic-booter-jar-with-dependencies.jar
As for changing this behaviour I'm not really an expert with Ubuntu but as far as I know it uses upstart to control applications to run at start up.
http://www.linux.com/archive/feature/125977?theme=print
I use the stand-alone version which I manually start as an unprivileged user.
delcypher
Postby Gus » Sun Aug 01, 2010 9:58 pm
delcypher, thank you very much for all your help. I'll be trying that and see how it works.
Gus
