need help with subair
Postby iamvoodoo » Sun Aug 01, 2010 6:22 pm
I just updated my subair and now when I open it it says required parameters missing. It worked fine until I updated. Help!
iamvoodoo
Same here
Postby iabstract » Mon Aug 02, 2010 5:44 pm
There was an update to the Adobe AIR and after that I'm getting the parameter error as well.
edit:
I was mistaken, the update was for subAir, not Adobe's AIR.
iabstract
Postby jrhorn424 » Mon Aug 02, 2010 7:29 pm
Also receiving this error.
jrhorn424
Postby rohren » Tue Aug 03, 2010 4:29 pm
I am also receiving this error after the update
rohren
Postby Numanoid » Tue Aug 03, 2010 6:24 pm
Same here. Clearly the update is broken. :(
Numanoid
Postby SUbSUB » Wed Aug 04, 2010 11:10 am
same here please fix it :shock:
SUbSUB
Temporary fix
Postby iabstract » Wed Aug 04, 2010 7:37 pm
In trying to troubleshoot the problem I've noticed noticed the following temporary workaround:
I use the subsonic address redirect (xxx.subsonic.org) for my server. Worked fine in .24, but not in .28. However, when I specified the direct IP/port address instead of the redirect, it worked properly, so the parameter error seems related to the redirect.
Note: you can also download and install the prior version from his website, which still works fine.
I notified the developer of this bug, so hopefully he's able to find a permanent fix shortly. Until then, I suggest using your direct IP/port address or downgrade to the older version (.24) and it should work.
iabstract
New version
Postby iabstract » Thu Aug 05, 2010 4:01 pm
The developer has released a new version, .030, that has resolved the problem for me.
iabstract
Postby rohren » Fri Aug 06, 2010 3:37 am
I downloaded version .030, and now I'm getting this error code:
200: Error #1096
rohren
Postby deftdrummer » Sun Aug 08, 2010 12:54 pm
I can confirm that the problem is related to the redirect. Using your regular IP address should work fine. Interestingly enough this release was specifically supposed to address this problem.
deftdrummer
