Access Denied when changing admin password
Postby digitalcan » Tue Aug 03, 2010 2:47 pm
Hi
I just install the windows version of subsonic to Windows 7.
When i log with the default admin password and want to change the password or try to enter settings page i am receiving access denied error
Access Denied.
Sorry, you are not authorized to perform the requested operation.
I installed the server to another windows 7 system and everything works fine but this system gives me this error.
Any solution ?
Thanks.
digitalcan
Postby digitalcan » Thu Aug 05, 2010 4:38 pm
no solution ?
digitalcan
Postby digitalcan » Fri Aug 06, 2010 11:37 am
My log is like that:
[8/6/10 2:31:22 PM EEST] INFO Schema35 Created avatar 'Turntable'.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Created avatar 'Vinyl'.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Created avatar 'Cool'.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Created avatar 'Laugh'.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Created avatar 'Study'.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database table 'custom_avatar' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database table 'custom_avatar' was created successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'user_settings.avatar_scheme' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'user_settings.avatar_scheme' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'user_settings.system_avatar_id' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'user_settings.system_avatar_id' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'player.jukebox' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema35 Database column 'player.jukebox' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema36 Updating database schema to version 12.
[8/6/10 2:31:22 PM EEST] INFO Schema36 Database column 'player.technology' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema36 Database column 'player.technology' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Updating database schema to version 13.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Role 'settings' not found in database. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Role 'settings' was created successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Role 'jukebox' not found in database. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Role 'jukebox' was created successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'music_folder.changed' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'music_folder.changed' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'internet_radio.changed' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'internet_radio.changed' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'user_settings.changed' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema37 Database column 'user_settings.changed' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema38 Updating database schema to version 14.
[8/6/10 2:31:22 PM EEST] INFO Schema38 Database column 'player.client_id' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema38 Database column 'player.client_id' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema38 Database column 'user_settings.show_chat' not found. Creating it.
[8/6/10 2:31:22 PM EEST] INFO Schema38 Database column 'user_settings.show_chat' was added successfully.
[8/6/10 2:31:22 PM EEST] INFO Schema40 Updating database schema to version 15.
[8/6/10 2:31:22 PM EEST] INFO Schema40 Reset stream byte count statistics.
[8/6/10 2:31:22 PM EEST] INFO DaoHelper Done checking database schema.
[8/6/10 2:31:23 PM EEST] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Sat Aug 07 03:00:00 EEST 2010
[8/6/10 2:31:23 PM EEST] INFO SearchService Search index not found on disk. Creating it.
[8/6/10 2:31:23 PM EEST] INFO SearchService Starting to create search index.
[8/6/10 2:31:23 PM EEST] INFO SearchService Created search index with 0 entries.
[8/6/10 2:31:23 PM EEST] DEBUG NetworkService Starting PortForwardingTask
[8/6/10 2:31:23 PM EEST] DEBUG NetworkService Starting URLRedirectionTask
[8/6/10 2:31:23 PM EEST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Aug 06 14:36:23 EEST 2010
[8/6/10 2:31:26 PM EEST] DEBUG NetworkService Completed URLRedirectionTask
[8/6/10 2:31:27 PM EEST] WARN NetworkService Failed to delete port mapping for port 80
[8/6/10 2:31:27 PM EEST] DEBUG NetworkService Completed PortForwardingTask
[8/6/10 2:31:38 PM EEST] INFO VersionService Resolved local Subsonic version to: 4.0.1
[8/6/10 2:31:38 PM EEST] INFO PlayerDao Created player 1.
[8/6/10 2:31:38 PM EEST] DEBUG TranscodingService Created player 1 (remoteControlEnabled: true, isStreamRequest: false, username: admin, ip: 127.0.0.1).
[8/6/10 2:31:38 PM EEST] INFO VersionService Resolved latest Subsonic final version to: 4.0.1
[8/6/10 2:31:38 PM EEST] INFO VersionService Resolved latest Subsonic beta version to: 4.0.beta2
I uninstalled the program and reinstalled it nothing changed i cannot log in to settings panel from the web browser. (Internet Explorer and Firefox used)
I am using Windows 7 32 bit. I don't use UAC on this computer. I think there is a problem with my user acount control mechanism but I am logging in with an administrative account.
Please help me. I really want this software.
digitalcan
Postby digitalcan » Fri Aug 06, 2010 12:05 pm
i have solved the issue
I go to services and found the subsonic service i click the properties and go to Log on and change the local system account to use this account and I give my user and password for the computer. I restart the service and it works perfectly...
Maybe somebody need this solution later...
digitalcan
Postby toif » Thu Sep 16, 2010 1:27 pm
I have the same problem here.
I tried your solution but it didn't work for me. I try both local admin and domain user/pass for service but none of them worked out. I can't access to settings at all. Can anyone help?
toif
