"Subsonic encountered an internal error"
Postby alemdohorizonte » Thu Aug 05, 2010 2:45 am
hi,
can anyone help me with the following error? (i've included the log because the error message to include it).
everything was working fine until late last night and now no matter what i try i cannot get subsonic to see my music folders.
thanks.
error message & log:
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Apple Inc. 1.6.0_20
Operating system Mac OS X 10.6.4
Server jetty-6.1.x
Memory Used 97 of 97 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
at java.util.regex.Pattern$BnM.optimize(Pattern.java:4946)
at java.util.regex.Pattern.compile(Pattern.java:1473)
at java.util.regex.Pattern.(Pattern.java:1133)
at java.util.regex.Pattern.compile(Pattern.java:823)
at java.lang.String.split(String.java:2292)
at net.sourceforge.subsonic.service.SearchService$Line.parse(SearchService.java:724)
at net.sourceforge.subsonic.service.SearchService.getIndex(SearchService.java:602)
at net.sourceforge.subsonic.service.SearchService.getStatistics(SearchService.java:349)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:120)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:132)
alemdohorizonte
Re: "Subsonic encountered an internal error"
Postby fridden » Thu Aug 05, 2010 8:12 am
I think you need change the memory limit (default is 100MB). I had the same problem and increased the limit and the problem was gone.
You can increase the limit by opening the Subsonic control panel and click on the "Settings" tab.
/Fridden
fridden
Postby alemdohorizonte » Thu Aug 05, 2010 10:34 am
thanks fridden.
where are you seeing the settings to be able to increase the memory limit? (i have a mac and have been through all of the settings tabs but cannot find anything relating to memory that i can configure (except kbps)).
alemdohorizonte
Postby fridden » Thu Aug 05, 2010 12:16 pm
Sorry, I am running Windows 7.
I just open the subsonic control panel and it has two tabs. The first one is "Status", the second is "Settings".
Under settings I have "Port number", "Memory Limit (mb)" and "Context path".
Perhaps somebody else running subsonic on a Mac could help out.
/Fridden
fridden
