Error writing mp3 output
Postby frankspin » Fri Aug 06, 2010 2:35 pm
I was looking through my logs today and I noticed this was popping up pretty sporadically. Upon further looking it appears to happen when two people are utilizing the transcoder. Is there anyway to work around this or will this just happen due to the inability for two people to access the same process at the same time?
FYI: transcoding is set up for mp3s because I have bandwidth cap from my ISP so I need to transcode higher quality files when using SubAir or Android App
Edit: Noticed this at the bottom of the log when no one else was streaming
[2010-08-06 08:49:21,781] INFO PlaylistInputStream - frank listening to "New American Gospel\01 Black Label.mp3"
[2010-08-06 08:49:21,783] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [-b] [96] [M:\Music\Lamb Of God\New American Gospel\01 Black Label.mp3] [-]
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) ID3v2 found. Be aware that the ID3 tag is currently lost when transcoding.
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 15115 Hz - 15648 Hz
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding M:\Music\Lamb Of God\New American Gospel\01 Black Label.mp3 to <stdout>
[2010-08-06 08:49:26,652] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding as 44.1 kHz  96 kbps j-stereo MPEG-1 Layer III (14.7x) qval=2
[2010-08-06 08:53:25,604] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Error writing mp3 output
[2010-08-06 08:53:26,274] INFO PlaylistInputStream - frank listening to "New American Gospel\02 A Warning.mp3"
[2010-08-06 08:53:26,276] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [-b] [96] [M:\Music\Lamb Of God\New American Gospel\02 A Warning.mp3] [-]
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) ID3v2 found. Be aware that the ID3 tag is currently lost when transcoding.
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 15115 Hz - 15648 Hz
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding M:\Music\Lamb Of God\New American Gospel\02 A Warning.mp3 to <stdout>
[2010-08-06 08:53:26,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding as 44.1 kHz  96 kbps j-stereo MPEG-1 Layer III (14.7x) qval=2
[2010-08-06 08:53:56,377] INFO PlaylistInputStream - frank listening to "New American Gospel\03 In the Absence of the Sacred.mp3"
[2010-08-06 08:53:56,380] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [-b] [96] [M:\Music\Lamb Of God\New American Gospel\03 In the Absence of the Sacred.mp3] [-]
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) ID3v2 found. Be aware that the ID3 tag is currently lost when transcoding.
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 15115 Hz - 15648 Hz
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding M:\Music\Lamb Of God\New American Gospel\03 In the Absence of the Sacred.mp3
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame)       to <stdout>
[2010-08-06 08:53:56,433] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding as 44.1 kHz  96 kbps j-stereo MPEG-1 Layer III (14.7x) qval=2
[2010-08-06 08:54:11,538] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Error writing mp3 output
frankspin
