Stream Subsonic Using iTunes
Postby wadebot » Sat Aug 14, 2010 8:30 pm
I'm trying to figure out how to stream from my subsonic site using iTunes. I would just use the web browser, but I have a couple of Apple Air Port Expresses that can be controlled through iTunes. That allows me to control where music is played in my house. I just want iTunes to open up subsonic streams is all.
Does anyone know if this is possible or how to do this?
Thanks in advance!
wadebot
Postby Kirk » Sat Aug 14, 2010 11:14 pm
I don't use iTunes that much... But could it possibly be used as an External player like WinAmp can be?
Kirk
Kirk
Postby wadebot » Sun Aug 15, 2010 2:42 pm
Thanks for the clue. I didn't setup the external players is all. I did that and now I can stream using iTunes just like Winamp does. Awesome!
wadebot
Postby Kirk » Sun Aug 15, 2010 7:35 pm
wadebot wrote:Thanks for the clue. I didn't setup the external players is all. I did that and now I can stream using iTunes just like Winamp does. Awesome!
No problem! Glad I could help. :D
Cheers,
Kirk
Kirk
How to use itunes
Postby rickkramer » Sat Aug 21, 2010 2:31 pm
Can you give the irstructions on how to stream the player using itunes on a Windows PC?
Rick
rickkramer
Postby Kirk » Wed Aug 25, 2010 11:39 am
Wow, I read your request on Sunday and haven't had time to answer yet! >.<
First you need to set up an External Player in Subsonic. This means one of the players from your Subsonic menu (Player 1, Player 7, whatever) must act differently.
To set up an external player:
- Login to Subsonic and go to Settiings on the top panel.
- Go to "Players" (toward the top)
- You'll most likely want "External Player with Playlist" (I haven't tested it with iTunes so if this behaves oddly try the one without a playlist).
- Save the player, and load a playlist or a few songs into that player.
- Now instead of seeing the Flash player, you'll see the word Play. Click that, save the playlist somewhere temporary, and open the playlist file with iTunes.
If you have any further questions, feel free to ask!
Cheers,
Kirk
Kirk
Users browsing this forum: No registered users and 61 guests
