Java error on startup
Postby Amadeus93 » Mon Aug 16, 2010 12:25 pm
Running 4.0.1 on Windows XP, I get the following error when I start up my computer (I've set the EXE4J_JAVA_HOME variable, but it didn't help):
Error
No JVM could be found on your system.
Please define EXE4J_JAVA_HOME
to point to an installed 32-bit JDK or JRE or download a JRE from www.java.com.
OK
Amadeus93
Postby Kirk » Mon Aug 16, 2010 6:34 pm
It doesn't look like you have Java installed on your computer. Go to www.java.com and click the big "Get Java" button. Then go through the installation process and try to start Subsonic again.
Cheers,
Kirk
Kirk
Postby Amadeus93 » Tue Aug 17, 2010 2:35 pm
I have Java installed, so that's not the problem. I thought Subsonic might have issues with the spaces in the path name (C:\Program Files\Java\jre6\bin), so I pointed the EXE4J_JAVA_HOME variable to C:\PROGRA~1\Java\jre6\bin instead, but it didn't help.
Any other thoughts? Perhaps reinstall Java to a simpler directory like C:\java?
Amadeus93
Postby Kirk » Tue Aug 17, 2010 4:50 pm
I've never had an issue... I just use the standard install paths and normal installs for JRE and Subsonic. lol.
I'm not sure I'll be able to be of any more assistance... :/
Cheers,
Kirk
Kirk
