use Subsonic.org ddns with WAR install
Postby 1000101 » Wed Aug 18, 2010 8:57 pm
I just installed subsonic on my QNAP NAS as a WAR install and was wondering if I would be able to use the <username>.subsonic.org feature to connect.
The issue I have is that the address would have to resolve to:
http://XX.XX.XXX.XXX:7080/subsonic
to be able to work correctly on Tomcat.
Any ideas?
1000101
Postby baaldemon » Thu Aug 19, 2010 2:29 pm
There should be no issue with it. Just in your settings makesure you have your subsonic configured to use the subsonic address. Log in as administrator then under settings->network check the access your server over the internet using an easy to remember address.
baaldemon
