Installing Transcoders on QNAP NAS
Postby GARGANCHUAN » Thu Aug 19, 2010 11:23 pm
I've tried installing lame and ffmpeg through ipkg and linking the lame and ffmpeg to the transcode directory, but it doesn't seem to work. Can someone with a QNAP NAS tell me how they did it? Many thanks.
Here's some examples of what I did:
[/share/HDA_DATA/subsonic/transcode] # ln -s /opt/lib/libmp3lame.la /share/HDA_DATA/subsonic/transcode/lame/libmp3lame.la
[/share/HDA_DATA/subsonic/transcode] # ln -s /opt/lib/libmp3lame.so.0.0.0 /share/HDA_DATA/subsonic/transcode/lame/libmp3lame.so.0.0.0
[/share/HDA_DATA/subsonic/transcode] # ln -s /opt/lib/libmp3lame.so.0 /share/HDA_DATA/subsonic/transcode/lame/libmp3lame.so.0
[/share/HDA_DATA/subsonic/transcode] # ln -s /opt/lib/libmp3lame.so /share/HDA_DATA/subsonic/transcode/lame/libmp3lame.so
I've tried many variations in naming, etc. Thanks again.[/quote]
GARGANCHUAN
Postby zekebgaf@gmail.com » Sat Oct 02, 2010 8:15 pm
I just completed this task on my TS-239 PROII
My linked /var/subsonic is located at /share/HDA_DATA/subsonic/
Install LAME. I used the ipkg qpkg then
# ipkg install lame
This installed the LAME libraries into /opt/lib
I used:
# ln -s /opt/bin/lame /share/HDA_DATA/subsonic/transcode/lame
I then restarted tomcat:
#/etc/init.d/tomcat.sh restart
And it worked.
I think your issue is:
should leave off the underlined part.
zekebgaf@gmail.com
Postby evoss » Thu Nov 11, 2010 6:32 pm
Hi
Wonder how to find # ipkg install lame
Regards Evoss
evoss
Postby zekebgaf@gmail.com » Fri Nov 12, 2010 11:04 pm
evoss wrote:Hi
Regards Evoss
ipkg is a QPKG that must be installed like java and tomcat. Once installed you can call it from the command line. It is a package manager.
zekebgaf@gmail.com
Users browsing this forum: No registered users and 63 guests
