Help with the Log in Page
Postby jared68 » Fri Aug 20, 2010 2:46 pm
Hello everyone, I am new to subsonic and was looking for help with the log in page. I am just looking to customize the log in a bit and have not seen what code is supported after looking through the faq's and what not.
I may just have missed any reference tools, so if you could point me in that direction I would be grateful :)
Thank You for any help!
jared68
Postby Kirk » Fri Aug 20, 2010 8:23 pm
Could you please explain what you'd like to customize? Your question is very vague...
Cheers,
Kirk
Kirk
Postby jared68 » Sat Aug 21, 2010 10:55 pm
Well, It's vague in the sense I am not sure what is supported. I was hoping to be pointed to something along the lines of a user guide.
I just want to customize the text message on the log in screen Mainly I just want it centered. I am not sure really what else I could customize at this point.
jared68
Postby jared68 » Fri Aug 27, 2010 3:16 pm
Ok, I guess what I am looking for is what tags can I use for the code.
I would consider myself a novice in regards to code. But can stumble through once pointed in a direction. It seems reference material is being built as I haven't seen anything on the Wiki.
I just for now want to center the current text. And haven't found a tag that seems to work.
is it html, xml,
Also once logged in and editing the tags for the "welcom message" What could I use here. I have tried bb code, and the like, but that doesn't work.
jared68
