name.subsonic.org isn't working
Postby omyard » Fri Aug 20, 2010 9:38 pm
I installed Subsonic last night and everything was working fine. Used it this morning too. After a while it stopped working and I tried to look at the network settings on subsonic and I get the following:
Status: omyard.subsonic.org is registered, but could not connect to it. (SocketTimeoutException)
Subsonic works fine on the MacMini it's installed on, but when I try and run it on my networked iMac I get the following error in Safari:
Safari can’t open the page “http://10.0.1.18:4040/index.view” because the server unexpectedly dropped the connection.
iSub also gives me an error regarding the URL being incorrect or Subsonic server being down.
I've checked port 4040 and it's open so I'm not sure what could be causing the error.
This morning when it was working well I went ahead and donated, got the e-mail and registered as well.
omyard
Postby omyard » Fri Aug 20, 2010 10:13 pm
Ok, so this is weird...
I reset earlier and it didn't fix anything. I just reset again to install the new OS X update and it works. Not sure if resetting it fixed it, or if something behind the scenes changed. It works now, which is good.
omyard
