Why do files show up in library, but not on playlists?
Postby TheRandom1 » Tue Aug 24, 2010 1:17 pm
I have several songs (at least one full album that I've found so far) that show up in my library in Subsonic, but for some reason won't show up in a playlist.
I can play the songs just fine, and have double checked that they are MP3s, so I'm a bit confused. Can anybody help? I'll gladly email a file or two over to see if it happens for anybody else as well.
TheRandom1
Postby Kirk » Sat Aug 28, 2010 8:45 pm
How do you mean... "won't show up on a playlist"? What happens when you try to add them to a playlist? O.o
Cheers,
Kirk
Kirk
Postby TheRandom1 » Mon Aug 30, 2010 3:28 pm
When I look for the song, it shows up in the library, but when I add it to a playlist, it doesn't show up. For example, I created a playlist with a few songs that don't show up, and it says the playlist is completely empty.
TheRandom1
Postby JMilesT » Tue Aug 31, 2010 6:46 pm
Most likely a discrepancy between what's listed in the .m3u file of your playlist, and the directory structure of your music collection.
JMilesT
Postby TheRandom1 » Thu Sep 02, 2010 1:42 pm
I don't understand what you said? I exported the .m3u playlist from iTunes into subsonic, and didn't change locations or anything of any files?
TheRandom1
Postby TheRandom1 » Tue Sep 14, 2010 6:31 pm
Anyone?
TheRandom1
Postby Kirk » Tue Sep 14, 2010 10:54 pm
Are you sure you're properly saving the player contents to a playlist after making your changes? Players (the + sign adds a song to the player) are not permanent. Playlists are permanent. Simply adding a song to the on-screen list will not add it to the playlist unless you save the playlist again. Is it possible that you are making this mistake?
Cheers,
Kirk
Kirk
Postby TheRandom1 » Tue Sep 14, 2010 10:56 pm
That cannot be the case here unfortunately. I am making the playlists in iTunes, and most of the other files show up in the playlist once it's loaded into subsonic.
I have also tried using Windows Media Player to make the playlist.
TheRandom1
Postby j3tblk » Fri Sep 17, 2010 12:56 am
TheRandom1 wrote:That cannot be the case here unfortunately. I am making the playlists in iTunes, and most of the other files show up in the playlist once it's loaded into subsonic.
Here you go:
http://tinyurl.com/28n9np4
j3tblk
Postby TheRandom1 » Fri Sep 17, 2010 1:36 am
Hey, thanks for being useless. I have m3u files and they work fine. I'm trying to figure out why only certain songs won't show up in them.
TheRandom1
Postby Kirk » Sun Sep 19, 2010 8:25 pm
Thread Fail.
Kirk
Postby TheRandom1 » Tue Sep 21, 2010 2:16 am
Wow...
TheRandom1
