Timing out with Time Capsule
Postby rollyfoster » Wed Aug 25, 2010 1:26 am
I can't get subsonic to connect to my computer via a Time Capsule router. It says computer is registered but the connection times out. how do i fix this?
thanks
rollyfoster
Postby Kirk » Sat Aug 28, 2010 7:40 pm
Are you trying to stream Subsonic on the local area network, or from the external Internet?
I'm guessing from the context of your question that you most likely do not have the ports forwarded for external access. My first suggestion is to find the local IP address of your computer and try to connect to it. For example, http://192.168.1.5:4040/ or something similar.
If you need help finding your LAN IP address, please do not hesitate to ask. (And include the operating system of your computer so we can help you with the specific task).
Your question is very vague... and I feel like this response is coming a little late. If you're still interested in pursuing this issue, then please respond to this thread with additional information and I would be happy to assist you.
Cheers,
Kirk
Kirk
