Covert art : Folder = Album?
Postby cyberdamienb » Wed Aug 25, 2010 6:04 pm
I have a question,
If I create a folder containing varius songs in a folder called "Others" for example.
All the songs come from different artits/albums.
They have all their own covert art but in subsonic it seems that only one covert art is displayed per folder and all the others song have now the same covert art...
Is it normal?
Bye
Damien
cyberdamienb
Postby Kirk » Sat Aug 28, 2010 7:07 pm
Yes. It's entirely normal. Subsonic can only display one cover art per folder as far as I know.
Your best bet, for consistency and logic, is to make a folder.jpg specifically for your Misc folder and then it will use that for cover art by default.
If you insist on having cover art for individual songs, the only way I know of to do that is to group them into subdirectories.
Cheers,
Kirk
Kirk
