Connection Failure. Wrong username or password
Postby swilner » Fri Aug 27, 2010 3:09 am
Trying to set this up on my Droid Incredible and my Windows 7 PC. I have paid the donation and copied/pasted my license key. The Network page says that my router is "successfully forwarding port 80". The same page also says that the subsonic.org web page with my name has "responded successfully". I can play music from within the subsonic program (version 4.0.1 (build 1529)), but I can't access it from my HTC Incredible. I get the message "Connection Failure: Wrong username or password". I have changed the admin password properly (I believe), but can't login to the webpage when I go to myname.subsonic.org.
I am not knowledgeable about tech matters, but I usually can figure out things like user names and passwords. Where did I go wrong?? Thanks for your help. It looks like a very cool program once up and running.
swilner
problem resolved, i think
Postby swilner » Fri Aug 27, 2010 5:08 am
OK, so it seems to be working now. The name that I had used for the myname.subsonic.org is now saying that it is in use. I changed the name to something less common and it is logging in.
swilner
Users browsing this forum: No registered users and 58 guests
