Using Subsonic on a college (or any restricted) network?
Postby thevoiceless » Mon Aug 30, 2010 5:05 pm
I just started college about a week ago, living in the dorms on-campus. Obviously, this means I don't have access to all of the network settings like I did at home. I've tried setting Subsonic to use port 80, but it doesn't seem to work (even though Skype does, which netstat says uses port 80 when running). I have both an xxxx.subsonic.org and a DyDNS domain that I can use, but it doesn't look like enabling automatic port forwarding in Subsonic works, so I'm at a loss as to what to try now.
I tried searching/Googling for people in a similar situation, but with no luck. Has anyone successfully gotten Subsonic working on a network without access to the router?
Running Subsonic 4.0.1 (build 1529) on Vista (primarily, I can boot into Ubuntu if need be) and trying to access it via a stock HTC Incredible running version 1.7 of the Subsonic app on Android 2.1 (at least at the time of this writing, the 2.2 update is supposed to be rolling out).
thevoiceless
