Music Folder Not Found
Postby greyson1973 » Tue Aug 31, 2010 6:06 am
Hey all,
I am new at this so please bear with me if this seems noobish.
I just installed Subsonic for the first time. I have set most things up, but I keep getting an error that says no music folder found. My music folder is d:\music and it has MANY sub folders. I noticed a few posts that subsonic doesn't like spaces, so I renamed the folder to remove the spaces. I am currently renaming all the sub folders to take out spaces and special characters. However, there IS music in the main D:\music folder. So why is sub sonic not picking it up? I just don't get it. I noticed someone had suggested settings > search > update indexes. So I tried that too. Nothing.
greyson1973
Postby delcypher » Tue Aug 31, 2010 11:10 am
Subsonic is fine with spaces.
You should check that music files and being searched for by subsonic e.g. .flac .m4a .mp4 .mp3
This setting can found at Settings > General in the "Music mask" text box.
You may need to update the search index after adding new file extensions to the music mask.
Hope this helps.
delcypher
Re: Music Folder Not Found
Postby scottl2k » Thu Sep 27, 2012 10:23 pm
I know this is an old topic, but I came looking for an answer before I found the solution for my installation:
It appears that Subsonic needs "write access" to the folders, which is unfortunate.
scottl2k
Postby neutrino15 » Thu Jul 03, 2014 4:43 am
In case anyone's searching for an answer in 2014, I was able to get around this problem by placing a symlink to the desired music directory (on remote NAS) inside of a local directory. I think the problem is that my remote drive name contains unwanted characters that Chrome->Subsonic->Java can't deal with on Ubuntu 14.
So I created a symlink /home/Music/NAS -> Some Network Drive directory, and point Subsonic to /home/Music/NAS
Subsonic seems to follow the symlink properly, at least in my case.
Hope this helps someone.
neutrino15
