Change port from windows manually
Postby Chadwick » Tue Aug 31, 2010 12:37 pm
my server is working (windows xp) but I need to change the port manually. My icon for the windows configuration brings up a small window with unreadable characters so I can't change it from there. Any way to change the port by editing a file with a text editor? I'm assuming it would be under the program files directory or the subsonic directory on my c drive. Anyone know where this setting is stored? Maybe in the registry? I also donated to the developer if that helps me get a quick answer
Chadwick
Postby kermit22 » Mon Sep 06, 2010 10:11 pm
I searched the registry but I didn't find the port settings in there and I wasn't able to find it anywhere else either... Perhaps you should PM Sindre to see if it is able to be changed without using the tray icon. Or else you could try reinstalling Subsonic to see if that will fix your corrupted tray icon.
kermit22
Postby Kirk » Sun Sep 12, 2010 3:36 pm
On linux, I believe Subsonic saves its settings to a file called "subsonic.properties". When I'm near a Windows PC I could check and see where it's saving this file if it exists. You could also try searching for it, but I'm not sure if the Windows version stores settings in this manner.
Cheers,
Kirk
Kirk
Users browsing this forum: No registered users and 50 guests
