album art search not working today?
Postby glycolized » Tue Aug 31, 2010 7:12 pm
I just installed and started using Subsonic this past weekend. I have been using the album art search feature from the web interface, and I am logged in as 'admin'.
I was able to use the "Search Discogs" button just fine yesterday, but today it seems to run the search very quickly only to report back "No images found.'
I am currently on a Ubuntu machine, and I tried with both Chrome and Firefox today. I also just tried Chrome on a W7 machine.
Is anyone else having an issue with this?
glycolized
Me either...
Postby sternebrau » Wed Sep 01, 2010 4:54 pm
Album art is not working for me either, for any album. Here's my log:
[2010-09-01 09:51:45,424] INFO CoverArtBatchService - Looking up cover art for Rise Against - The Sufferer & The Witness.
[2010-09-01 09:51:45,491] WARN CoverArtBatchService - Failed to retrieve cover art for Rise Against - The Sufferer & The Witness: org.apache.http.client.ClientProtocolException
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:643)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:576)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:554)
        at net.sourceforge.subsonic.service.DiscogsSearchService.executeRequest(DiscogsSearchService.java:170)
        at net.sourceforge.subsonic.service.DiscogsSearchService.searchForReleases(DiscogsSearchService.java:100)
        at net.sourceforge.subsonic.service.DiscogsSearchService.getCoverArtImages(DiscogsSearchService.java:70)
        at net.sourceforge.subsonic.service.CoverArtBatchService.doRunBatch(CoverArtBatchService.java:94)
        at net.sourceforge.subsonic.service.CoverArtBatchService.access$000(CoverArtBatchService.java:37)
        at net.sourceforge.subsonic.service.CoverArtBatchService$1.run(CoverArtBatchService.java:68)
Caused by: org.apache.http.ProtocolException: The server failed to respond with a valid HTTP response
        at org.apache.http.impl.conn.DefaultResponseParser.parseHead(DefaultResponseParser.java:109)
        at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:210)
        at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:271)
        at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:227)
        at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:209)
        at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:292)
        at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:126)
        at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:483)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
        ... 8 more
sternebrau
Postby zOOge » Thu Sep 02, 2010 9:08 am
Same error here, depressing since I installed Subsonic yesterday ;)
// Fredrik
zOOge
Postby sternebrau » Thu Sep 02, 2010 4:43 pm
This is still happening after my 3rd day of having Subsonic installed. I absolutely love it, and the the album art problem is the only thing holding me back from donating now. I should mention my server information:
Version: 4.1.beta1 (build 1759) – August 21, 2010
Server: jetty-6.1.x, java 1.6.0_18, Linux (28.2 MB / 62.9 MB)
I am running this on Ubuntu 9.04 (Jaunty).
/etc/version: Linux version 2.6.28-11-server (buildd@palmer) (gcc version 4.3.3 (Ubuntu 4.3.3-5ubuntu4) ) #42-Ubuntu SMP Fri Apr 17 02:48:10 UTC 2009
Since I have multiple virtual hosts on this server, and it's behind a strict firewall, Subsonic is running on port 4040, which is being proxied from port 80 with nginx. (I can share the nginx config if anyone wants).
Everything is working amazingly well except for the batch cover art downloads.
sternebrau
Failing Coverart Search
Postby toolman » Thu Sep 02, 2010 7:16 pm
I.ve been using Subsonic several moths now and up till a few days ago Cover Art search worked fine. :D
Guess that there have been some changes on the Discogs-site which have a negative effect on Subsonic.
To bypass this you could always search Google Images for a cover and paste the url manually.
I know it's not the best solution but for an occasional update it works.
Guess that Sindre ( or someone else :roll: ) has to do a bit off code-crunching to get it working again.
BTW I'm using the Subsonicversion 4.0.1 (build 1529) on Windows XP Pro.
toolman
Re: Failing Coverart Search
Postby sternebrau » Thu Sep 02, 2010 7:27 pm
toolman wrote:Hi,
I've done the manual artwork updates for a couple albums, but since I'm a newbie, and I have just imported all my albums in, the manual option is more work than it's worth. Hope the batch artwork is fixed soon! :)
sternebrau
Postby gmarcom » Thu Sep 02, 2010 8:13 pm
Just installed the Beta:
And the search discogs is still not working
gmarcom
Postby cactus88 » Tue Sep 14, 2010 9:32 pm
I've never had a working cover art search...always "No images found."
I have 4.1 (build 1806) – September 10, 2010 installed.
Are others still having problems?
cactus88
Discogs is really not working anymore
Postby toolman » Tue Sep 14, 2010 10:18 pm
I'm using version 4.0.1 (build 1529) – 13 may 2010 and the coverart search used to work fine until several weeks ago.
As I said in a previous post: It seems that there have been some changes on the Discogs website which causes this problem.
I tried today to find some covers on Discogs, but all I get from subsonic is:
No images found.
toolman
Postby purplerhino » Wed Sep 15, 2010 2:16 pm
4.1 didn't help either. Sure glad I did my whole-library fill before it broke, so I can survive for the time being manually setting new additions. Is irritating though!
purplerhino
it's Final
Postby toolman » Thu Sep 16, 2010 12:06 pm
Now I'm sure that the cover-art problem arises from changes on Discogs.
XBMC also used to use Discogs for Cover-art, but can't find anything anymore.
This feature also used to work fine in XBMC.
toolman
Postby supra92 » Tue Sep 21, 2010 5:03 am
Cover art search fails for me as well, using the new 4.1 on Linux via Tomcat6.
Didn't Subsonic used to use Amazon as well as Discogs? I always had better success with Amazon search and was surprised to see Sindre remove that from Subsonic cover art search options. I guess Amazon changed it such that it wasn't as Subsonic-friendly or something?
I just added 450 albums, and the idea of manually searching in Google images and pasting in the URL for each one is making me shiver.
supra92
Postby alphawave7 » Tue Sep 21, 2010 6:09 am
supra92 wrote:Cover art search fails for me as well, using the new 4.1 on Linux via Tomcat6.
While not a Subsonic solution, MediaMonkey still uses Amazon (also in AMZ's various country sites, if Amazon US can't locate it). It's Auto-Tag feature will save it to the ID3 tag of each file, so it travels WITH the file, not stuck in a silo like iTunes/WMP. You can also scrub Google Images,etc. and save/apply in MM similarly. G'Luck!
Postby bcgrown » Sat Sep 25, 2010 4:04 am
You can add another "me too" to this list -- Subsonic 4.1, build 1806, running on Linux. It would be really nice to have this feature back!
Here's my log:
[2010-09-24 20:56:05,123] INFO CoverArtBatchService - Looking up cover art for Boogie Down Productions - Criminal Minded.
[2010-09-24 20:56:05,144] WARN CoverArtBatchService - Failed to retrieve cover art for Boogie Down Productions - Criminal Minded: org.apache.http.client.ClientProtocolException
   ... 8 more
bcgrown
Another me too
Postby TTown » Sun Sep 26, 2010 6:17 pm
Slightly different error message though:
[26.09.10 11:54:36 MESZ] WARN CoverArtBatchService Failed to retrieve cover art for Zebra - : java.net.UnknownHostException: www.discogs.com
Subsonic installation details:
    Version 4.1 (build 1802) – 10. September 2010
    Server jetty-6.1.x, java 1.6.0_21, Windows XP (95,3 MB / 247,5 MB)
TTown
Users browsing this forum: No registered users and 71 guests
