NO VBR songs working since upgrading to 4.1beta1(build 1767)
Are you having trouble with VBR playback?
Yes
0
No votes
No
1
100%
Stop using VBR you dolt!
0
No votes
Total votes : 1
Postby rwt2777 » Wed Sep 01, 2010 1:11 pm
I had no trouble with these VBR encoded songs until upgrading. Is there a way to fix this? I have hundreds of VBR songs mixed into my 300GB+ collection of music?
rwt2777
Postby kermit22 » Wed Sep 01, 2010 4:37 pm
I haven't tried out the beta yet, but 90% of my songs are V0 quality VBR so that would definitely be a bummer if this bug made it to the final 4.1 release.
Are you limiting your bittrate or have your transcodings changed or anything like that?
-My Subsonic Server-
OS: Windows Server 2016
Processor: Intel Xeon E5630
Memory: 8GB
2,098 artists
4,266 albums
39,450 songs
2,606 hours
kermit22
Postby rwt2777 » Wed Sep 01, 2010 4:50 pm
Nope - no bandwidth limitations and I changed nothing with the transcoding.
rwt2777
Postby delcypher » Wed Sep 01, 2010 5:23 pm
Are you streaming your VBR (mp3s I assume, you didn't say!) directly without transcoding or are you transcoding your VBR [INSERT_CODEC_HERE] files?
If you are transcoding how about actually looking at subsonic.log and seeing what is going wrong with the transcoder? Maybe post that part of the log file here. You also don't say what you're transcoding to (VBR MP3, Ogg Vorbis, CBR MP3,etc.)!
You also didn't say what you're streaming to. E.g. the web player or an external player( e.g. vlc).
Saying "it doesn't work" isn't very helpful. So what actually happens when you try and play the files.
If you want the problem to be fixed you need to be a lot less blunt.
delcypher
Postby rwt2777 » Wed Sep 01, 2010 5:35 pm
Sorry about that... here's what was in the log:
[9/1/10 1:32:07 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\faad] [-w] [E:\Music\iTunes\iTunes Music\Coldplay\A Rush Of Blood To The Head\04 The Scientist.m4a]
[9/1/10 1:32:07 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[9/1/10 1:32:07 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Warning: unsupported audio format
rwt2777
Postby rwt2777 » Wed Sep 01, 2010 5:38 pm
It should be noted that ALL of these .m4a files played previously, I just couldn't skip around within the track - it was either play, pause, listen through, or start the track over again.
Now it won't play them - really puts the halt on A LOT of playlists I have.
PS: Playing via browser
rwt2777
Postby delcypher » Wed Sep 01, 2010 9:51 pm
lame isn't able to understand what is coming faad. One of the following has happened since your upgrade.
* You've changed one or more of your transcoding tools since the upgrade
* Your transcoder commands are incorrect (what I believe is happening)
* Subsonic isn't handling the transcoders properly.
I've tried simulating your commands and I believe your lame transcoder command is wrong. It should be (tells lame to assume raw PCM input and not search for a wave header)
lame -r -b %b - -
not
lame -x -b %b - -
Although if you get static rather actual music then you may need to play with the --signed , --unsigned, --little-endian, --big-endian options.
Either way the -x is completely wrong because it is for use with the --decode options (for reading mp3s and outputting wav files)
Personally I prefer to use ffmpeg instead of faad. See my transcoder article on the wiki for more info http://sourceforge.net/apps/mediawiki/subsonic/index.php?title=Transcoders#Transcoding_to_MP3
I hope this helps.
delcypher
Postby rwt2777 » Wed Sep 01, 2010 10:29 pm
I really have no idea what these commands are but here's what's currently in for m4a > mp3:
Step 1: faad -w %s
Step 2: lame -b %b -x - -
Should I still put in what you said should be in there? And if so, do I put it in the "Step 1" field or the "Step 2" field?
rwt2777
Postby delcypher » Wed Sep 01, 2010 11:29 pm
I made a mistake in my previous post, please re-read it.
Anyway this is listed on the wiki but I'll repeat myself...
Your transcoder settings for m4a > mp3 should probably be as follows
Step 1: faad-w %s
Step: lame -b %b -r - -
(Basically replace -x with -r in your original transcoder setup)
or
Step 1: ffmpeg -i %s -f wav -
Step 2: lame -b %b - -
If you don't know what the options should do you should run (from cmd.exe).
lame --longhelp
and
faad --help
Which explain what each option does.
delcypher
Users browsing this forum: No registered users and 55 guests
