Problem with non-latin characters
Postby deadfolk » Thu Sep 02, 2010 7:03 pm
I seem to be having a problem streaming files with non-Latin (Japanese, in my case) characters in the filename. The stream just never starts.
I think the problem is with transcoding, as MP3 files seem to work, but FLAC do not.
Has anyone else seen this problem? Is it a known issue?
Thanks for any help,
Matt
deadfolk
Postby delcypher » Thu Sep 02, 2010 7:11 pm
If you take a look at subsonic.log it will show how a transcode is progressing. You'll probably see an error message describing why the transcode failed.
The most likely cause is the %s substitution is not being done correctly by subsonic. But a copy of the part of the log that shows the problem would be useful.
What operating system are you using and filesystem (e.g. FAT,NTFS,ext2,ext3,HFS)?
delcypher
Postby deadfolk » Sat Sep 04, 2010 3:36 pm
Thanks for your reply.
I'm using Windows 7 64-bit. NTFS.
Here's the relevant part of the log:
[2010-09-04 16:29:00,852] INFO PlaylistInputStream - deadfolk listening to "i_flancy\02 ????????.flac"
[2010-09-04 16:29:00,854] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [K:\media\music\shared\flac\Hitomi Yaida\i_flancy\02 ????????.flac] [-f] [wav] [-]
[2010-09-04 16:29:00,859] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-] [-]
[2010-09-04 16:29:00,916] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2010-09-04 16:29:00,916] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2010-09-04 16:29:00,916] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2010-09-04 16:29:00,917] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) K:\media\music\shared\flac\Hitomi Yaida\i_flancy\02 ????????.flac: no such file or directory
Obviously, the file isn't really called 02 ????????.flac.
Your browser might not render this correctly, but the filename is '02 未完成のメロディ.flac'. It's in Japanese.
deadfolk
Postby RevMen » Tue Nov 02, 2010 8:23 pm
aha! This thread just helped me figure out why I can stream some .flac files but not others. The ones with non-English characters in their names never start. Is there any known fix for this?
RevMen
Postby deadfolk » Tue Nov 02, 2010 9:18 pm
No...never did get to the bottom of it.
I'm kind of stumped, but there doesn't seem to be any form of support channel other than this forum, so I have given up for now.
deadfolk
Postby RevMen » Tue Nov 09, 2010 5:38 pm
I noticed it's not just .flac, but .mp3 files fail as well if they have funny characters in their name.
RevMen
