Hard Drive failure and user recovery....
Postby I_Died_Once » Sat Sep 04, 2010 5:14 pm
Hi all... I have been using subsonic for quite some time now and have had a handful of friends obtain accounts.
Well, my hard drive crashed and I decided to reinstall my operating system (Debian Linux) on a new hard drive. Since then, I've installed subsonic again and re-set everything up accordingly....
Except I would like to migrate my user and password info to my new setup so I don't have to reassign everyone names and passwords again. I have managed to mount the damaged hard drive and recover several gigs of data... its telling me I have a bad superblock... whatever... I can access my data now and if there is a way to bring everyone back on without registering everyone again, that would be terrific.
Thanks a lot!
I_Died_Once
Postby delcypher » Sat Sep 04, 2010 7:35 pm
In your subsonic install directory (usually /var/subsonic or /usr/bin/subsonic) there should be a directory called "db" this contains your Subsonic database and settings.
If you copy this across this to your new Subsonic install then you should be fine.
delcypher
Postby RevMen » Wed Oct 20, 2010 12:44 pm
In case it's of use to anyone...
I just finished migrating my Subsonic install to a new machine. I copied over the entire subsonic installation directory, then I installed subsonic on top of it on the new machine. It worked great; everything's there except the chat messages.
RevMen
Postby alphawave7 » Thu Oct 21, 2010 3:19 am
RevMen wrote:In case it's of use to anyone...
Handy to know! Thanks! :)
