Tables and so on
Tables and so on
Postby rodskin » Wed Sep 08, 2010 8:24 pm
Hi where can I find where users and passwords are kept? Is it a MySql table or what?
Rodskin
rodskin
Postby delcypher » Thu Sep 09, 2010 6:13 am
Subsonic uses HSQL. However everytime Subsonic stops running it puts some information /path/to/subsonic/install/db/subsonic.script
When Subsonic is started again that file is used to recreate some of the database.
If search that file you'll find a line similar to this
INSERT INTO USER VALUES('admin','enc:61646d696e4',0,0,0,FALSE)
Passwords are hex encoded ('enc:' indicates this which is not part of the password).
Hope that helps
delcypher
Users browsing this forum: No registered users and 50 guests
