Can't access subsonic through the webui?
Postby fuzzy191 » Thu Sep 09, 2010 8:59 pm
First off, I love subsonic, it's the cheapest way to stream all my music to many of my friends. On that note, I recently donated to keep the streaming to other computers and phones but now I can no longer access subsonic on any computer other than the one all the music is stored on. The ui says that I have fuzzy.subsonic.org successfully registered and yet, whenever I try to access it from another computer I have a problem connecting. Can it have something to do with the fact that my ports aren't successfully forwarded on my computer? Any help is appreciated.
fuzzy191
Postby stueyboy » Thu Sep 09, 2010 10:11 pm
I'm assuming these other PC's are outside your own network. If they are inside, you will need to use the IP address with the port number instead of the DNS name you registered.
Dunno what's up if they are outside your network...
stueyboy
Postby fuzzy191 » Fri Sep 10, 2010 12:58 am
Yeah it's outside and inside my network that I can't access
fuzzy191
Postby oeh » Fri Sep 10, 2010 1:41 am
It's the port forwarding that is causing your problems.
Try to go to:
http://www.yougetsignal.com/tools/open-ports/
Regards
OEH ;-}
oeh
Postby stueyboy » Fri Sep 10, 2010 10:10 am
I'm assuming you are pretty comfortable with forwarding ports but just in case, look here for instructions for just about every router available
http://portforward.com/
stueyboy
