Windows Media Lossless playback problem
Postby iatepaste » Fri Sep 10, 2010 12:09 am
Hi all!
First off, Subsonic is great and exactly what I've been looking for.
A portion of my library is ripped to WMA lossless using dbPowerAmp. When I try to play these files back, nothing happens. I searched for the issue and found some things suggesting it might unsupported by ffmpeg but other posts on this forum lead me to believe otherwise. I built a new copy of ffmpeg but the issues continued.
Here's the part of the log that looks pertinent:
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Input #0, asf, from 'c:\music lossless\Sam Cooke\Portrait of a Legend 1951-1964\Sam Cooke - 09 - I'll Come Running Back to You.wma':
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Duration: 00:02:10.99, start: 3.000000, bitrate: 510 kb/s
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: 0x0163, 44100 Hz, stereo, s16, 1152 kb/s
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Output #0, wav, to 'pipe:':
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream mapping:
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0 -> #0.0
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Unsupported codec (id=86057) for input stream #0.0
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Assuming raw pcm input file
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 17249 Hz - 17782 Hz
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding to
[9/9/10 1:59:32 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
Not sure what else to do here but any help would be appreciated!
iatepaste
Postby Frisco Bill » Sun Sep 12, 2010 4:24 pm
You need to use wmadec to transcode lossless wma files.
wmadec -b 16 %s -
There is a new version of lame in the transcode pack.
for lame 3.98.4 use the "-r" option for pcm input.
lame -b %b -r - -
for the older version I think the lame command needs to be:
lame -b %b -x - -
Frisco Bill
Postby iatepaste » Mon Sep 20, 2010 3:04 pm
Worked perfectly. Thanks a ton!
iatepaste
