All settings lost after installing 4.1
Postby radiodave » Wed Sep 15, 2010 4:56 pm
I just installed 4.1 onto my system which had been running 4.1-beta.
After the install I notice that the Subsonic Control Panel shows that the service has reverted from my Port Number setting to port 80.
When I go to Subsonic in the browser, my admin password has reverted to the default and all my other custom settings are gone.
Is there any way to get my settings back?
I'm running Subsonic on Win XP SP3.
radiodave
Postby Kirk » Sun Sep 19, 2010 7:13 pm
When myself and my friend upgraded our Linux Subsonic servers, we did not encounter a problem like this.
The best advice I can give you is to check if the path you installed to is the same. I believe Subsonic on Windows keeps its settings files in its program folder, so if you inadvertently installed it to a different location that might have caused the settings to be dislocated from the program.
Aside from searching for the file, I can't think of any other way to restore your old settings.
Cheers,
Kirk
Kirk
