Error 503 and 404 after update
Postby Aethies » Thu Sep 16, 2010 3:54 pm
Already fixed this issue, but wanted to put this out there in case someone else ran into this problem.
I updated to 4.1 and somehow the database got corrupt. I didn't realize this until I was updating the nic with a gigabit card in the host server and when it came up, subsonic wouldn't. Logs didn't show anything, but after blowing away the /var/subsonic/db directory, it worked again. Tried to copy this directory back from a backup and it stopped running again.
The only thing I lost out of this was my users. Not sure where they are stored for backups, but I am back up and running again.
Anyway, take care and see ya on the flip side.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby Kirk » Sun Sep 19, 2010 8:01 pm
I'd like to figure out why a few users have experienced this issue. Did you upgrade to the beta first, or straight up upgrade from 4.0.1 to 4.1?
Cheers,
Kirk
Kirk
Postby Aethies » Mon Sep 20, 2010 1:31 pm
Kirk wrote:I'd like to figure out why a few users have experienced this issue. Did you upgrade to the beta first, or straight up upgrade from 4.0.1 to 4.1?
Cheers,
Kirk
Well, here is something that I found out. What happened was this:
Was running 4.0.1 for a while. I then installed the 4.1beta, and never restarted the server. Then installed 4.1, and when the service came back up, said there was STILL a new version. Downloaded it again and re-installed it again. This time I had to restart the server to install a new NIC. When it came up, it wouldn't start up. Logs showed the database corruption.
In short, installing 4.1, removing the webapps/subsonic folder and re-applying the 4.1 seems to have caused the issue. Don't know how, don't know why. But for some reason, it happened.
I think in all of this, I may have inadvertently not stopped the tomcat6 service after the second time and applied the update WHILE the service was running, thus corrupting the database.
I don't think it is anything with the install process or subsonic.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby yatzr » Tue Sep 21, 2010 1:31 am
I had this just happen to me. Thanks for the steps on fixing it.
Here's the error my log had when trying to start up subsonic. I don't think it holds the key as to why the database became corrupt though.
3250 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@c08593{/,jar:file:/C:/Program%20Files/Subsonic/subsonic.war!/}
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'podcastService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 260 java.io.IOException: java.io.IOException: Unexpected end of command
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:101)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:58)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$1.run(Unknown Source)
Caused by: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 260 java.io.IOException: java.io.IOException: Unexpected end of command
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:58)
at net.sourceforge.subsonic.dao.PodcastDao.getAllChannels(PodcastDao.java:67)
at net.sourceforge.subsonic.service.PodcastService.getAllChannels(PodcastService.java:167)
at net.sourceforge.subsonic.service.PodcastService.init(PodcastService.java:100)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
... 56 more
Caused by: java.sql.SQLException: error in script file line: 260 java.io.IOException: java.io.IOException: Unexpected end of command
at java.sql.DriverManager.getConnection(Unknown Source)
... 72 more
yatzr
Postby yatzr » Tue Sep 21, 2010 1:41 pm
I should mention one thing I did right before my database became corrupt. I keep all my music on its own harddrive and I had booted up the computer without that harddrive connected a few times. Subsonic started automatically those times, but I never opened a client (I was troubleshooting a different harddrive which is why I had disconnected the music harddrive). Once I was done, I connected the music harddrive again. After I booted up, I tried accessing subsonic and I got a 503 due to the corrupt database.
yatzr
Same trouble with 4.1 and java error
Postby ericnyoder » Wed Sep 22, 2010 3:22 pm
I tried to delete the directory, but it is not there on the machine. I have attempted the upgrade on 2 separate machines (mac mini running 10.5.8 - intel on both) - Neither has this directory /var/subsonic/db databse
Can you provide with a little more assistance. Thanks.
ericnyoder
4.1 issue with Java
Postby ericnyoder » Thu Sep 23, 2010 11:49 am
BTW - I discovered this only happens with 4.1 - I went back to 4.0.1 and its working fine now. Strange. On mac 10.5.8 with newest Java installed.
ericnyoder
Users browsing this forum: No registered users and 50 guests
