AudioScrobbler
AudioScrobbler
Postby nextyear » Tue Feb 13, 2007 12:36 pm
Ive updated to the beta subsonic 3.0.beta1 (build 391) (running on a win2K box) with Apache Tomcat 6.0.9. Ive tried to setup the last.fm support under appearance for my user account (with correct details etc & saved)...when trying to run a stream for my account on my pc (win xp sp2), last.fm logs in ok but doesnt scrobble the song (under now playing in last.fm nothing is showing) - checking the log file for subsonic shows just this error -
"WARN AudioScrobblerService Failed to scrobble song 'You're All I Have' at Last.fm. Unknown response:"
Im running v 1.1.3.0 of last.fm with winamp plugin v 2.0.30.0
Playing an mp3 direct into winamp scrobbles fine.
Just wondered if its something simple thats causing this issue that I havent picked up on,
Many Thanks,
mike.
nextyear
Postby sindre_mehus » Tue Feb 13, 2007 12:44 pm
Hi Mike,
That's weird... Does it happen all the time?
Postby nextyear » Tue Feb 13, 2007 1:36 pm
Doh,
Just realised it was something really simple after all - The box which is running subsonic was locked down for internet access :oops: ...changed it now and its fine
Thankyou for your time
kind regards
mike.
nextyear
Postby sindre_mehus » Tue Feb 13, 2007 1:39 pm
No worries, mate :D
