Error on Home page
Error on Home page
Postby Leonard26 » Fri Sep 17, 2010 3:59 pm
I get the following error when subsonic loads the home page:
Exception javax.el.PropertyNotFoundException
Message Property 'lastModified' not found on type net.sourceforge.subsonic.controller.HomeController$Album
I've never been able to see the home page. Subsonic works great otherwise.
Any ideas?
Leonard26
Postby Kirk » Sun Sep 19, 2010 8:34 pm
I am under the impression that the Home page relies on the Search index being up-to-date. Does the search tool work? If not, try updating your search index and report back to us.
What do you mean you can't see the home page? What happens when you go to it? A blank page on the Subsonic template? An error message? A blank page entirely?
Cheers,
Kirk
Kirk
Postby Leonard26 » Mon Sep 20, 2010 2:18 pm
Thanks for your reply Kirk.
The Search tool seems to work fine. I can search by using the 'any', 'title', 'album' and/or 'artist' fields and it return correct results.
I re-ran the search index, and I was able to get the home screen window to load. I see the random, newest, highest rated, etc links. However, once I click on one of them, I get error page with the stack trace. The home page then will not load unless i re-run the search index again... strange.
Let me know if any more details are necessary...
Leonard26
Postby Leonard26 » Thu Mar 10, 2011 7:05 pm
Sorry to bump and old thread, but I'm still having this issue on version 4.4 All other functionality works fine...
Thanks for any help!
Leonard26
Users browsing this forum: Google [Bot] and 11 guests
