4.1 Upgrade Issue - "Unsupported format"
Postby wvilla » Fri Sep 17, 2010 11:24 pm
Evening all,
I just upgraded to 4.1 and none of my music now plays (it is all in m4a, but that has never been an issue). Any ideas as to what could be causing this?
Attached are the logs and my settings:
[9/17/10 7:25:43 PM EDT] INFO PlaylistInputStream admin listening to "Best of AC DC\01 For Those About To Rock (We Salut.m4a"
[9/17/10 7:25:43 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\faad] [-w] [C:\Users\xxxxx\Music\iTunes\iTunes Music\Music\AC DC\Best of AC DC\01 For Those About To Rock (We Salut.m4a]
[9/17/10 7:25:43 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[9/17/10 7:25:43 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Warning: unsupported audio format
wvilla
Postby Peachcake » Sun Sep 19, 2010 7:37 pm
I have the similar problems playimg wma for some reason. Related?
[9/19/10 1:27:49 PM MDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\wmadec] [D:\Music\Bloc Party\Intimacy\Talons.wma]
[9/19/10 1:27:49 PM MDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[9/19/10 1:27:49 PM MDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Warning: unsupported audio format
Peachcake
Postby Kirk » Sun Sep 19, 2010 7:49 pm
It would appear that LAME is not getting the right kind of input. Would you guys mind pasting your relevant lines from the "Transcoders" Settings panel on Subsonic, so we can see how your transcoding is set up?
Cheers,
Kirk
Kirk
Postby Peachcake » Sun Sep 19, 2010 7:54 pm
wma > mp3 Step 1 wmadec %s Step 2 lame -b %b -x - -
These are the default settings.
Peachcake
Postby kenz » Sun Sep 26, 2010 8:40 pm
same problem for me :
wmadec %s lame -b %b -x - -
kenz
Postby kenz » Wed Sep 29, 2010 7:14 am
so is there any solution ?? or I can just delete all my wma albums collection ? :cry:
kenz
Postby Peachcake » Tue Oct 05, 2010 7:36 pm
I couldn't find a fix for this so I downgraded back to 4.0.1 and its working fine again. I won't update until there is a fix for this.
Peachcake
Postby kermit22 » Tue Oct 05, 2010 9:35 pm
I just wanted to double check that you are using a player that has the transcodings checked in the players page in the settings menu. Subsonic likes to make new players and select them without asking you.
For the longest time I couldn't figure out why my mp3 transcodings to a lower bitrate weren't working and then I realized that the player that I was using didn't have the correct transcodings set up but one of the other players did.
kermit22
Postby kenz » Wed Oct 06, 2010 7:42 pm
for me it's already activated :(
kenz
transcoding settings
Postby bpschroder » Sat Oct 09, 2010 12:28 am
you will need to change your transcoding settings
[code]cbr:
step 1
wmadec -b 16 %s -
step 2
lame -b %b -r - -
or vbr:
step 1
wmadec -b 16 %s -
step 2
lame -v -b %b -r -
bpschroder
Postby kenz » Mon Oct 11, 2010 12:09 pm
what do you mean bu cbr or vbr ?
do I need to create a new transcoding line or do I just change the wma > mp3 line ??
kenz
WMA lossless
Postby bpschroder » Mon Oct 11, 2010 3:34 pm
you will need to change your default WMA > Mp3 settings. I chose vbr (variable bit rate) since the lossless wma format is variable, but I have had no problem with constant bit rate files either.
bpschroder
Postby kenz » Mon Oct 11, 2010 8:14 pm
it worked !! THANK YOU VERY MUCH !
kenz
Postby Peachcake » Tue Nov 23, 2010 4:42 am
I upgraded again to 4.2 and changed those settings like you mentioned bpschroder. I tried the vbr and cbr made sure no others were defaulting or enabled for WMA > mp3 and I still didn't get anything to play. Any ideas?
Peachcake
Postby Exrace » Tue Nov 23, 2010 5:34 am
Sounds like you might have a local issue judging from your previous posts if subsonic is not throwing any errors in the log.
Have you tried another computer to access your subsonic setup?
What OS is running your subsonic setup?
Maybe a conflicting or missing support for the formats?
Exrace
