[SOLVED] Theme change doesn't change login screen.
Postby reaper829 » Sat Sep 18, 2010 11:25 pm
When I change the theme, it doesn't change the login screen - the login screen stays the the default. I'm using the war version of subsonic with opensuse 11.3. Any ideas?
reaper829
Postby rodan1967 » Sun Sep 19, 2010 3:16 am
While not the exact problem I am having but when I change theme while logged as admin the theme does not change. When I login under a different user the theme is different for everything except the album list which is still the original theme..
rodan1967
Postby bormuff » Sun Sep 19, 2010 11:53 am
When you 'change the theme' are you just changing it for your user, or are you setting the default theme to be your new theme via Settings -> General -> Default theme ?
bormuff
Postby reaper829 » Sun Sep 19, 2010 4:34 pm
D'oh! Good call bormuff. That fixed it. Thanks everyone.
reaper829
