Modify Login Screen?
Postby rodan1967 » Sun Sep 19, 2010 10:56 pm
Is there a way to modify the login screen so I could use my own graphics or images in place of the ones that come with Subsonic?
rodan1967
Postby supra92 » Tue Sep 21, 2010 4:59 am
You sure can -- look for the following file in your install. The path below is for Tomcat6:
/usr/share/tomcat6/webapps/subsonic/WEB-INF/jsp/login.jsp
Any images you want to add/display should go in the following dir:
/usr/share/tomcat6/webapps/subsonic/icons
This, again, assumes Linux and Tomcat. The standalone Jetty server version should be fairly similar (just use the normal subsonic home path). As for Windows, I'm guessing it's similar but have never tried it.
Regards,
Supra92
supra92
