java.lang OutOfMemoryError
Postby benje101 » Mon Sep 20, 2010 7:36 pm
Hi I'm getting the following error box, I was wondering if anyone can help at all ?
PS, the library is over a TB and is accessed over Gb ethernet connection
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_21
Server jetty-6.1.x
Memory Used 96 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
also, not a problem entirely but I've a small conundrum, my music library is on a folder on my NAS ...if enter the path to this folder directly in my subsonic settings page it all seems to work (even tho I'm not supplying any account/login info for the NAS network share to subsonic, strange!) but if i enter in Subsonic settings the address for the same network share as the windows mapped network drive it is set to, then it does see it?? (odd in a different way). any thoughts on that.
thankyou all freeware developers!
benje101
Postby benje101 » Tue Sep 21, 2010 2:17 pm
Any ideas at all..?
...I am far from a computer expert but I could probably edit some settings files ...possibly even use some different JVM if req'd.. if I'm pointed in
the right direction.
many thanks for any assistance on this
Cheers
benje
benje101
Postby kermit22 » Tue Sep 21, 2010 3:27 pm
If you increase your memory you should be fine. Follow this guide by Kirk to increase your memory usage.
http://forum.subsonic.org/forum/viewtopic.php?t=3939
kermit22
Postby benje101 » Fri Sep 24, 2010 7:36 am
many thanks.
yep that was all it was.
works great now.
Sindre your amazing :)
I've donated before, I'll donate again when I can afford it x
benje101
