Seek for Audio tracks bugs out sometimes
Postby varunsrin » Tue Sep 21, 2010 9:05 am
Sometime's I've noticed when I'm streaming audio files through the web the seek bar in the player bugs out and I can't skip within the track anymore. A refresh of the window usually sorts it out, but it happens again for the next track I load.
Browser: Chrome 6
The issue does not seem to occur on Firefox. Can someone else please verify this for me?
varunsrin
Postby kermit22 » Tue Sep 21, 2010 12:28 pm
I see the same thing on Chrome 6.0.472.62.
kermit22
Postby varunsrin » Tue Sep 21, 2010 3:34 pm
Interesting, does anyone know if this is an issue with Flash or Chrome or subSonic itself? I'm guessing Flash but I have no idea how to debug this...
varunsrin
Re: Post subject: Seek for Audio tracks bugs out sometimes
Postby deuce32 » Wed Oct 20, 2010 4:48 am
I am having the same issue in Chrome and IE 8.
In both of those browser the seek bar usually works for the first song I play after logging in (regardless of the file format) and then stops working for every other song.
Is this a known issue?
deuce32
Postby seanpkeown » Wed Oct 20, 2010 4:54 am
I fixed this problem by replacing the jw player in subsonic. The current version is 5.0 but i updated mine to 5.3 and everything is now good. http://www.longtailvideo.com/players/jw-flv-player
seanpkeown
Postby 2Bmobile » Fri Oct 22, 2010 10:30 pm
seanpkeown wrote:I fixed this problem by replacing the jw player in subsonic. The current version is 5.0 but i updated mine to 5.3 and everything is now good. http://www.longtailvideo.com/players/jw-flv-player
YES! This finally helped me to solve my "Error writing mp3 output" issue. I thought that this was an encoding issue (ogg -> mp3) and spent hours on it trying all kind of encoding settings. But it vanished once I used the JW 5.3 release.
Should be included in the next release to save us all from some headache
:D
2Bmobile
Postby kermit22 » Tue Oct 26, 2010 12:57 pm
I downloaded the new jw player but I'm not sure what files to put in which directory. I'm using windows XP.
kermit22
Postby GJ51 » Tue Oct 26, 2010 1:48 pm
Thanks for the link. I downloaded the 5.3 Player files, but I too am not quite sure what to do with them.
Can you post instructions on how to do the update?
I have jw-player-4.4.swf and jw-player-5.0.swf in
C:\subsonic\jetty\1802\webapp\flash
None of the other files such as swobjet.js or jwplayer.js are in this directory.
Any assistance appreciated.
On the right trail, just a little lost, too.
Postby jacobthe4th » Tue Oct 26, 2010 5:44 pm
I have downloaded them and replaced the player, in:
Is this the right step? If so, should I restart the server to apply the changes?
Not really sure once I retrieve it, what are the proper steps to get things running with the newer player.
Jacob
jacobthe4th
Postby seanpkeown » Thu Oct 28, 2010 12:22 am
Ok.... so there are two ways to replace the jw-flv-player. The lazy way which is the way i did it or the hard way which i won't teach because it takes too much time. :D
Ok so first download flash player 5.3. http://www.longtailvideo.com/players/jw-flv-player
Depending on where flash player is installed will differ depending on where you have subsonic installed.
I'm guessing that most of them are installed here.
My flash player is installed here but thats because i'm running subsonic off of tomcat.
C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\subsonic\flash
You should find two files under your flash folder. jw-player-4.4.swf and jw-player-5.0.swf. Now rename the jw-player-5.0.swf to jw-player-5.0.old.swf and paste the player.swf that you just downloaded in to the flash folder and rename it to jw-player-5.0.swf. After you do that you may need to reboot subsonic and also delete your internet temparary files before it will work.
To verify that it worked run the subsonic web page and right click on the flash player and it should say About JW Player 5.3.1.... or something.
Let me know if it works.
~ Sean K
seanpkeown
Postby GJ51 » Thu Oct 28, 2010 12:54 am
Thanks much!
Will test tonight.
Postby GJ51 » Thu Oct 28, 2010 2:40 am
I instsalled it and it works well with music. The seek bar functions properly.
Only problem now is that it won't play video. I kinda suspected that the other files in the upgrade pack might be needed for that. Guess I'll have to poke around inside to see if I can figure out the hard way.
Postby kermit22 » Thu Oct 28, 2010 12:21 pm
Thanks seanpkeown your solution works great.
kermit22
Thanks!!!
Postby jacobthe4th » Thu Oct 28, 2010 3:06 pm
:D
Works Great!!!
jacobthe4th
Postby GJ51 » Fri Oct 29, 2010 8:53 am
jacobthe4th
kermit22
With Video?
Users browsing this forum: No registered users and 62 guests
