Playlist is Empty
Playlist is Empty
Postby WelcomedRain » Tue Sep 21, 2010 2:56 pm
Maybe I'm just doing something wrong... but I have stored playlists from Exaile and Rhythmbox and am able to designate the folder within Subsonic where they exist. Subsonic sees them but when I go to load the playlists I get the message the they are empty. Am I not doing something right? I can open them in both media players and they work fine and I can even import them between the players and they are read in each player but Subsonic doesn't seem to be able to recognize the lists.
Thank you for any help.
WelcomedRain
Postby JulesG » Mon Nov 01, 2010 10:26 am
I have EXACTLY the same problem. M3U playlists made in Windows Media Player. Can anybody help ?
Update: solution found !
http://forum.subsonic.org/forum/viewtopic.php?t=4248&start=0&postdays=0&postorder=asc&highlight=playlist+empty
JulesG
Postby alphawave7 » Mon Nov 01, 2010 3:21 pm
There are also playlist proggies that do this 'path redirection' with the click of a button. Shane Brinkmann's 'JBSynch' has an m3u playlister, very easy to use, and it can load/manipulate the relative path by checking a box.
