Is there a way to force a reload of the whole library?
Postby rashley » Wed Sep 22, 2010 6:30 pm
I recently added another folder of new music and it doesn't show up when I select 'newest' from 'home'. The new albums show up in the browser on the left.
Also, the stats at the top of the browser don't reflect the new additions.
rashley
Postby bormuff » Wed Sep 22, 2010 6:40 pm
Go to Settings -> Search -> Update search index now
Wait a few seconds for it all to update (you can check when its done via the log under 'More') if you want.
To update the stats, then just right-click inside that pane and reload just that frame (different browsers will handle the menu for this differently).
bormuff
Postby rashley » Wed Sep 22, 2010 7:32 pm
Thanks. I couldn't find it.
rashley
Postby jonthemonster » Tue Oct 26, 2010 2:18 pm
Thanks bormuff. Worked for me.
jonthemonster
