can subsonic playlist relay to shoutcast or icecast?
Postby darvil » Thu Sep 23, 2010 10:08 am
I feel like this can be done but I have yet to find any info after scouring this forum and the web for a while.
Basically I have a forum with a mod which connects to a shoutcast server.
What I'm interesting is it subsonic to relay to the shoutcast/icecast server. Basically have a playlist on subsonic relay to it.
Is this possible? Has anyone here done it before?
darvil
Postby Kirk » Fri Sep 24, 2010 3:20 am
The best way I can think of is to use WinAmp as a Shoutcast server, and have it connect to Subsonic as an external player.
Subsonic itself? No. Not that I know of.
Cheers,
Kirk
Kirk
Postby darvil » Fri Sep 24, 2010 4:59 am
Kirk,
Do you know if shoutcast can play the playlist the subsonic creates? That might work but I'm not sure if the playlist subsonic makes are unique.
I can install shoutcast on the same server as subsonic.
darvil
Postby alphawave7 » Fri Sep 24, 2010 5:32 am
darvil wrote:Kirk,
Winamp/Shoutcast has never had any problems for me with either relative or absolute path m3u's, so it should work! Ensure the m3u is in the same directory or in a parent directory of the mp3 files. What mod are you using, and is this phpBB or vBulletin?
Postby darvil » Fri Sep 24, 2010 7:02 am
Excellent! What I'm planning is to do is to have like a "general" playlist that the shoutcast runs on. Which only I and some mods can modify. The shoutcast will be connect to the forum mod and will play the song like a radio.
Members will also be able to login to subsonic with their forum account. This part someone on the forum is writing a bridge script for me. I hope it works out. Essentially subsonic becomes a collective collection of songs just for forum members.
FYI I'm using this mod
http://dev.bouncyservers.co.uk/
Its for invision forum 3
darvil
