Recently not connecting.
Postby fastfriends » Thu Oct 07, 2010 1:18 pm
I've been using Subsonic for a couple months & it's great, but now it's not connecting to server. This is on both my desktop web browser & Android app. I haven't changed any settings, so I can't figure out what is happening differently. I was hoping for some insight on how to troubleshoot the problem. I've tried to connect with the firewall off & I've checked my port forwarding. My music is on a laptop connected to a wireless router, but it's worked flawlessly until about a week ago. I'm not very tech savvy, so any help is appreciated.
-a small additional prob: When I look on http://localhost, it says I am registered but it also says I still need to donate (which I already have) to use the subdomain url.
Thanks in advance.
fastfriends
Postby Kirk » Thu Oct 07, 2010 10:41 pm
For donation issues, you should PM sindre.
Do you have the ability to re-enter the license code? If you do, then do that first. (Donate button on the upper right corner of Subsonic).
Cheers,
Kirk
Kirk
Postby fastfriends » Sat Oct 09, 2010 7:21 am
It must still recognize that I donated, since there is no place to re-enter the code.
I guess there is some issue with the "easy-to-remember address" option, because I deselected that, connected with my ip address & it is back to working fine again.
Not ideal, but I got my tunes back. Definitely better than buying an expensive microsd card to store all these files!
fastfriends
