Change welcome screen structure.
Postby stranger » Mon Oct 11, 2010 8:12 am
Using Subsonic for a few days now and it seems to work perfect.
Only thing i would like to change/modify is the welcome screen.
It starts with 10 random albums to choose from.
It would be great if i can modify the layout of it, 6x3 instead of the current 5x2.
Is this possible?
:update: Modifying the refresh rate would also be handy.
stranger
Postby WildWalker » Mon Oct 11, 2010 9:38 am
If you pick 15 as the default instead of 10 you will get 5x3. is that close enough?
Alan.
WildWalker
Postby stranger » Mon Oct 11, 2010 11:28 am
WildWalker wrote:If you pick 15 as the default instead of 10 you will get 5x3. is that close enough?
Alan.
And where do i set that value?
I was unable to find it in current settings options.
stranger
Postby WildWalker » Mon Oct 11, 2010 3:42 pm
When you login you see the home page with the 10 album covers
below this is a drop down menu (depending on your resolution, you might have to scroll that frame down slightly), there you can change the defaul 10 albums per page to 5, 10, 15, 20, 30, 40 or 50
Alan.
WildWalker
Postby stranger » Mon Oct 11, 2010 4:10 pm
WildWalker wrote:When you login you see the home page with the 10 album covers
Alan.
I noticed that to but it's not a permanent solution.
I would like to see such configuration per user profile.
stranger
Users browsing this forum: No registered users and 58 guests
